It is currently Sat Jul 26, 2025 4:06 pm
PostPosted: Mon Apr 25, 2005 4:07 am
Anybody use one of these for blowing away the fine dust while routing for inlays? I used to just blow it away when it built up but have gone to using a dust mask and that method just doesn't work anymore. Now it's rout a little, stop, reach for air hose, blow off, start again. Gotta be a better way.
PostPosted: Mon Apr 25, 2005 4:20 am
I have one. Personally (and bluntly) I think it sucks.
1) The pump is really not strong enough to blow it away agressively.
2) Rather than blowing the pearl (or wood) dust all over the place I would rather suck it up.
I took my vac and stepped the nozzle down into 1/2" clear plastic tubing and tape that near where I am cutting the pearl or routing the pockets.
That seems to do a good job keeping the area clean and I only wear a (good) paper mask (not the full respirator).
Brock Poling38467.5562037037
PostPosted: Mon Apr 25, 2005 5:02 am
Good idea with the vacumn Brock, I'll try that. I was wondering if those aquarium pumps had enough omph for the job.
PostPosted: Mon Apr 25, 2005 5:04 am
I use an airbrush compressor blowing away from myself and a dust collection vent sucking what the compressor blows toward it. I still wear a resporator.
PostPosted: Mon Apr 25, 2005 5:50 am
Oh, one other thing I have found useful.... and this applys more to cutting the pearl than routing the pockets....
If you know you are going to be cutting small pieces I have a little piece of screen I put over the end of my hose so I can catch the pieces should they get away from me.
PostPosted: Mon Apr 25, 2005 6:45 am
Brock this tip seems as if there may be experience behind the logic
PostPosted: Mon Apr 25, 2005 7:03 am
After I cut the same part 3 times only to watch it disappear I thought... "you know... there has got to be a better way...."
PostPosted: Mon Apr 25, 2005 12:42 pm
I use a shop vac bungee corded under my work paddle. I keep it on a momentary footswitch sometimes, if doing little projects, usually it's just on during the whole project. If you're afraid of sucking up pieces, stretch a pantyhose over it.
In my shop, I vacuum everything. Rarely will a broom ever touch dust or shavings. Especially stuff that's toxic or stuff that causes an allergic reation
PostPosted: Mon Apr 25, 2005 11:58 pm
   I use my air drived unit and tap the air from the exhaust to keep the dust off my work. Before that I use the old straw in the mouth trick. A also found a dust collector on a funnel worked well.
   Reguardless you need to use somthing as the dust isn't good for you
john hall
